I realize I am reviving an old thread... but I have a question about my 2.2L Mazda B2200
I have the Autolite 2100 carb with 1.01 venturi, and #46 jets. I have welded an adapter plate to the intake to fit the autolite 2100 to the B2200 intake, I will be using a proform 9" round breather.
My truck has the stock cam, 8mm wires, and a factory coil from an EFI B2200, and a pacesetter header. The head and intake have been port matched using a felpro gasket on the intake and exhaust sides.
I used an online tool to calculate the flow, if I have entered the correct data, the engine should flow between 200 to 210 CFM.
I see that you guys are leaning towards the 1.08 venturi and 49 jets for he 2.3L.
Will the carb that I have.... be a good match for the 2.2L... and should I change the jet sizes?
