'84 BII C-5 behaving oddly.
Hoosierman
Forum Member
Indiana
My truck will only start in neutral, which I understand it to mean the NSS is suspect. Well, I removed the NSS almost a year ago, and since the PO nicely included a new Standard NSS with the truck among other parts, I went ahead and swapped it in, followed the service manual advice.
The truck still won't start in park, could be an adjustment issue I suspect-- but that's NOT the reason for posting this, though I mentioned it because it may be relevant.
I recently was servicing the drum brakes and today I started the truck, out it into reverse to get out of the driveway, and I noticed I had almost no braking power. No problem, I'll just put the truck back and take a different one. Well, when I put the truck into PARK, it kept wanting to go forward! What's more, it seems the E-brakes decided they didn't want to show up for work today, because when I couldn't get them to stop the vehicle, I managed to turn off the engine and in my situation, pulled the lever into DRIVE and the truck still wants to roll backward.
A linkage issue maybe?
You have 4x4? Perhaps the transfer case isn't fully engaged?
UPDATE in case those who stumble upon the same issue need guidance.
It was a manual shifter linkage issue. I must say that I have 6 different manuals for this truck which cover this topic. They use almost identical language and they weren't the most clear language. But it ultimately wasn't hard to figure out and it was easy enough. Now the truck does exactly what it needs to in each gear and it starts in Park. Yes, even with the NSS properly adjusted, it still wouldn't start in Park because it didn't see the gear in Park.
Furthermore, if you're wondering if this is your issue, I found a useful trick to find this out. When shifting through the gears with the main shifter in the cab, moving forward through each gear from 2-R, I heard the shifter click FIRST and then slightly forward of that, I heard the transmission itself engage. When I moved to Park, I heard the shifter click, but no engagement. Once I performed the adjustment, the clicks occurred exactly when the transmission would engage.
