B2cami
- Feb 2, 2015
I have an 84 b2 2.8l. To start out this problem i will say that i have removed the computer not using the duraspark conversion. This would be my second time doing this only did not have this problem with the one done before this. both done the exact same way. Pulled the computer only leaving the start,run and coil wires coming out of the distributor. Also problem occurs using both the motorcraft 2100 and 2150 carburetor both have been soaked and completely rebuilt. the symptoms consist of a rough chugging idle and no power. You try to drive and all it wants to do is barely move and chug. we adjusted the timing and fuel mixture. has good dist cap button and new plugs and wires. along with new pump gas lines sending unit and filter. Both me and my father n law are confused as to what it may be and he is a ford mechanic. Please any help would be greatly appreciated. will post a video of it running with and without the throttle engaged if needed.
