83 Full-Width SAS
77+ is all disc
I Got My Dana 60 Rear End Fo My Build Its Out Of A 78 Dodoge 3/4 ton I Think It Will Be A Good Rear End To Start With...
i too am currently dropping in a dana 44 with leafs im using the one out of a 79 ford. ive finally ripped out all old TTB crap and sold the 6inch lift from my 86 Ranger. Ive got the front hangers all figured out but im not exactly shure how im gunna do the rear hangers yet can you post some pics of your rear hangers. Since i want to run full size axle withs and they need to be off set from the frame how did you do yours
Well Its Been Awhile Since I'v Been On Or Able To Work On My Ranger Due To Winter And Work But Over The Winter I Was Able To Stock Up On Parts And Well This Week I Got Back To Work On The Truck And Here It Is With The Dana 60 In The Rear And New Rear Leafs And The Front Sittin In I Still Need To Lift The Front And Weld The Rear Diff In
that is sittin on 31's
Wear your mouthguard when going over railroad tracks.
Holly leaf springs batman!!!!!
I would take out a few in the rear pack to level with the front, your going to bust your teeth out over bumps (or a kidney).
But other then that looks pretty good.
you could weld some 2 inch DOM solid to the axle from the frame and take out the leaf packs to save some weight. it will ride the same.
you aren't seriously going to use those leaf packs are you?
I Dont Want Much Flex I'v Kinda Changed The Plans For The Truck Its Going To Be More Of A Mudd Bog And Bumper To Bumper Pull Truck
