- May 18, 2008
- 92 & 83 project
- Automatic
hi all,
needing to know if these pins are correct for a 83, gas, gauges, 2.8 (when originally built) .... no electricity in the truck, dash is semi apart, truck is being rebuilt.
here is link to the 18 pins on the cluster.
http://www.therangerstation.com/forums/showthread.php?t=156485
top right is the pin block i am going off. thanks for any help.
#1 ..... yellow/white fuel sending
#2 ...... white/red oil sending
#3 ....... open
#4 ........ open
#5 ........ black / light green ground ?
#6 ........red/orange ground for amperage meter ?
#7 ........open
#8 ........ red/white temp sending
#9 ........ yellow/light green amperage positive ?
#10 ...... light blue/red panel (dimmer lights)
#11 ..... open
#12 ...... red/yellow ???????
#13 ...... pink/white ???????
#14 .......black ground
#15 .......dark green/light green seat belt
#16 ....... light green/black right turn signal
#17 ........ white/light blue left turn signal
#18 ........ light green/white high beams indicator
#3 ....... open
#4 ........ open
#7 ........open
#11 ..... open
