8" skyjacker class2 lift
rangerdestroyer
i got a 92 ranger im looking to maybe buy that 8" skyjacker class 2 lift for it im just wondering if its worth me buying and what kinda tire size would i be able to run with it.
No such thing as a 8" class II kit (Class II is 4 & 6" only). The 8" comes only as class 1.
Like said above, the 8" kit makes a nightmare of the steering. I would stick with a 4 or 6" lift (using a body lift for the addl inches if you really need to be up that high).
If you have a heavy nose, (winch bumper, supercan, and a 4.0L V) you can get away with a Class II 6" kit with 8" coils (if you order them seperately and sell the 6"ers).....Keep in mind that the steering HAS to be dealt with properly @ anything about 4".
Your options (search these phrases):
FA600 Extreme drop pitman arm
Modified Superrunner kit
Stonecrusher steering
You can run 33x12.5 no problem, or 35's with a body lift and some fender trimming...go look in the tech library there is a chart showing how much lift you need to run certain size tires.
:icon_thumby::icon_thumby:
Ask away, we have all the answers lol :icon_twisted:
Lift mods
Does anyone know if you can use cut and turned beams with the skyjacker lift with radius arms? Also what about drop shackles and coil spacers for a bit more lift?
Nothing in theory should prevent you using C&T beams together with a bracket lift such as Skyjacker's (infact it's common to do just that with 2-3" lift brackets to avoid having more than 3" of C&T on the beams themselves). Putting C&T beams onto a 4" or taller bracket lift is gonna be a lot of lift though, and will almost open the steering can-o-worms the same as the 8" bracket lift alone does.
Again I would say it's a lot better to use a body lift for anything above 6" lift in the suspension (that or a Dana44 solid front axle swap, on which the steering is a bit easier to deal with at nosebleed lift heights).
