best one is out of a Explorer...right width, bolt pattern, and have the larger axle shafts....
at my JY's they will charge the same amount with or without brakes when getting a complete axle...so if you find a 95+ Ex you will already have discs mounted so you won't need to swap anything...
just remember you need to weld on new spring perches cause all Ex's were spring under....as well as shock mounts...
l8r, John
