rangerT
I have a 00' XLT sport and how do i tell if i have a 8.8. or 7.5 and what gearing too?and what spline would i have as i am interested in a posi upgrade......any suggestions?.....
thanks
thanks
There should be a small rectangular tag bolted to the diff cover more than likely on the right side it should say something like 3L73 but that's an example it will depend on if you have an open diff or lmtd slip, if you don't have the tag or can't find it you can read the sticker on the driverside door pillar right below the door jam and use the tech library to help decode it, ps don't use the vin# its the other #
if you dont see an L then it means you have an open diff. but every tag ive seen so far doesnt have the : between the numbers ill give you a better example the tag on my truck says 4L10 8 8 which is stating the i have a limited slip with 4.10s and the 8.8 rearend if your seeing 3 73 with no letters chances are you have an open diff ill insert a pic of a tag http://www.mre-books.com/images/image35.gif thats the link ignore everything but the gear ratio number and the ring gear size
