- Mar 4, 2013
- Automatic
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- not sure yet 15 x 10 wheels
if i parallel the explorer spring perches will that give me the correct pinion angle?
Probably not. Because when you move the spring to the top of the axle, the axle becomes lower in relation to the transmission, therefore the pinion would have to be angled up more.if i parallel the explorer spring perches will that give me the correct pinion angle?
everything ive read here in the swap section says 6*. I only want to do this once lol Plus I am adding Calvert racing traction bars to help me get some traction. Also should I leave the thickest overload spring out for better weight transfer?
