8.8 swap in 1984 BII, a little help please.
Sweet-85'
Hastings, MN
2.8 V6
If it ain't broke, fix it 'till it is!
Well, I've not had the luck finding what info I need. We've hit a block getting everything hooked up.
What do I need to make my Bronco II drive shaft work with the 8.8? A hybrid u-joint, if so, does anyone have a part number? It's just a standard 8.8 from a 93 Ranger. I'll be running a driveshaft spacer, so length isn't an issue, just getting the two hooked up is...
Thanks for any help!
Probably a hybrid joint, but I don't know which one.
