mudslinging79
- Jan 14, 2011
for those swapong a 7.5 for the 8.8 flange there are a couple ways to go if you want to use your old driveline. one is a u-joint, part number 5-134x. there are 2 arms longer to take the larger explorer yoke on the rear flange, as well as the 2 regular length arms for the stock 1310? u joints found on the 7.5 rear end driveline. also there is the yoke that bolts to the stock 8.8 flange, that takes the stock 1310 u joints, part number c2-2-671 16. this replaces the stock u joint yoke for the 7.5 rear end, and bolts directly to the 8.8 flange.
