Bronco Bob
- Dec 29, 2011
- Automatic
With the pinion gears holding side gears,, why put the c-clips onto axles,, the disc brakes keep axles in position?? Just curious, anybody?
Well, guess may as well pull cover and install, found on workbench afterwards
Where do you guys come up with this nonsense? C-clip eliminators keep the axle from falling out if you break an axle. If you have disk brakes the rotor/caliper keeps the axle from falling out if you break. I don't think they even make c-clip eliminators for disk 8.8's. When your axle is working correctly the axle isn't getting slapped around on the pads. If it did every time you turned you would grind against your pads.
The only plus you do get if you get an eliminator kit is the outer bearings. Usually they are bigger than the stock ones. Which adds a tiny amount of overall strength.
Sent from the road while ignoring traffic
