I like the setup Alwaysfloored has pictured. It is simpler than having something like the first picture and trying to tie those two pieces together somehow. Weezl, your thoughts are similar to mine, I think. The stock setup and stock perch give a fulcrum farther from the center of the axle, reducing the tension force on the U bolts for a given torque on the axle. In the first setup, the perch could move in theory, giving control of axle rotation to the lower part. The only potential problem I see with this is that the U bolts can not supply compression force, thus the fulcrum becomes the center line of the axle, applying significantly more tension on 2 of the U bolts than a stock type setup or a setup like alwaysfloored made. I would bet that there is still little chance of breaking them unless you were doing the drag strip thing. Still, if I ran that type of setup, I think I would be sure to keep my U bolts tight. The existence of a completely bolt on axle flip is very cool, and I would not hesitate to run a setup like alwaysfloored has.
