7spd Stick for Bronco?
85_Ranger4x4
Wallows in rivers
TRS Event Staff
OTOTM Winner
SW Iowa
Not shooting the messenger but....Jeeze, who would want a 7-speed, I don't even like 5 speeds in a truck
Love to have a 3 speed with OD so a 4 speed.
But to each their own :)
I guess the newer engines just have narrower RPM torque range so need the closer ratios
The ecoboost engine should have anything but a narrow torque range.
That would actually awesome. If it's a. nice deep 1st and 2nd gear that you don't really have to use on a daily basis. Kinda like a big truck you could start in 3rd gear and it's basically a 5speed with 2 extra low gears when you really need them. It's actually the best of both worlds if you think about it. Tall gears drive gears for mileage with overdrive to meet government standards plus 2 extra low gears that are available when needed.
On the column?
LOL, I learned manuals driving "3 in the tree", never saw 4 in the tree but sure wouldn't want 7 in the tree :)
Dad's '57 Bel-Air has a three speed on the tree and then a handle under the dash you pull for overdrive.
Column shift? I'm talking about a real stick shift manual transmission. Definitely not this multiple overdrive transmission bs that's going on now.
I was teasing Ron about a column shift since he wanted a 3spd.
I assume the Bronco will be console shift no matter what trans you have.
cool, with a wide ratio box that could eliminate the transfer case. no more stopping to change ranges.
Still needed for 4wd.
I'm talking about granny low gears for 1st and 2nd gears with a low range transcase. 2 way low gears to get it done regardless of what you are doing.
practical or not, I'm sure there's a way to integrate a front output and do away with most of the transfer case.
a ZF 5 speed (wide ratio) already has 5.72 first and a .76 fifth. add another lower 1st and the hi/low range t-case would not be needed. for normal driving use 3rd thru 7th.
RonD/85Ranger4x4:
My mom's Fairlane had a 4 spd column shifter, I believe the pattern was:
R 2 4
1 3
Neighbours had a Datsun mini-truck with 5 speed on tree.
Even when I was in high school, column shifting manuals slowed down the masses from being able to drive your truck.
pjtoledo:
Do you mean eliminate low range versus eliminate the transfer case?
I'm actually surprised more manufacturer haven't integrated the t-case into the transmission. Building transmission and transfer case all as one unit does make them more rigid - we see that already with integral bell housings
Drawback are:
It commits you to one supplier for both the transmission and transfer case. Expertise in one area doesn't necessarily mean expertise in the other.
And eliminating low range also removes the options of a deep low range ala NP241OR in the Jeep Rubicons.
But Ford probably needs to pick its battles there: desert/mud, not rock crawler.
The other one which surprises me is that there aren't more cam, aka sequential, shifted manuals. Motorcycles have had them for decades. You still have the control of a manual, but don't need worry about missing a gate. (Much easier for beginner to learn).
Quaife in the Nissan Skyline has both sequential shifter and integrated transfer case.
lvwill:
I hear you on crawl ratios, but I doubt it happens - high gear multiplication in transmission means you need thick shafts/large bearings in transmission to support, heavier u-joints, thicker driveshafts, larger differentials - all of which add weight and friction. Given the CAFE limits, we're stuck with double overdrives. :(
Personally:
I was thinking more likely the ZF 6 speed ratios, i.e. 5.79 1st, 0.72 6th then 0.57 7th with 5.13 axle ratios. Ideally, I would go even deeper with 1st, e.g. NP435 6.68 1st. Then your crawl ratio in 1st isn't significantly different than the M5OD 1st - 3.40, low range in 1354 - 2.48 with 3.73 gears, which was the most common configuration.
If your building a fully synchronized, i.e. including reverse, 6 speed, adding 7th speed only requires ~4cm, a sychro, needle bearing, snap ring and 2 gears. Much less than 10+cm for low range, and fewer parts. Based on a BW1354, low range needs: sun gear with needle bearing, planet carrier (which is a 4 part assembly) with 3 planet gears, ring gear, snap ring, shifter fork (which is a 3 part assembly) with wear pads. 5 parts vs 15, of which it is 2 versus 5 for the precision machined gears.
So, if you're reducing cost of manufacture, go with the 7 spd Lighter/costs less/better fuel economy & meets requirements of most.
Would need to see that 4 & 5 on the tree stuff. Was it just for Canada and Europe ?
