1986bronco2
- Mar 1, 2013
if you just read my previous post called ford trucks then you obviously know that i have a question about my newly acquired 79 f250. my question is this. what would cause the brake pedal to travel almost all the way to the floor before the brakes engage? i did a slow backwards and stomp and the same going forwards. when going backwards the front tires locked up(so i know i have front brakes) when i went forwards i did the same and the truck just stopped.so could this be a master cylinder issue or is this more of a rear brake issue? the only reason im asking is because i need to resolve this problem asap so that i have a way to work and back. and i need to know what the most likely cause of this problem is so that i can replace the nesessary parts first to either fix of eliminate the problem as the cause of this issue. i dont really know much about brakes other than how to replace the front rotors,pads,and calipers. also i checked the fluid level in the master cylinder and it was full. i pumped the brakes repeatedly to check for leaks and to see if the fluid level dropped any and i didnt see any leaks and saw no fluid loss. so that eliminates the brake line(s). so any info would be greatly appreciated. thanks,bill
