mazda warrior
how do i know what rear end i have in my 1997 2.3L 4 cyl. manual trans. mazda B2300 or aka ranger? i dont know if it has a 7.5 or 8.8 ford rear because both came in them? so how can i tell???
4 cylinders got the 7.5 I would think...
Check your axle code on the sticker inside the door. If it starts with a 8 or F, you have a 7.5... 9 or R is 8.8"
http://www.therangerstation.com/tech_library/Axles.html
Find your axle code on there and it'll give you your ratio.
Alternatively you could find the tag on the axle. Probably a metal strip hanging off one of the cover bolts. That link will help you decode it.
thanks guys i will definitely do that and secondly i have a 8.8 limited slip rear end from a 89 ford bronco full size would that fit under the ranger without being too wide or will it hang out too far?
... And as far as i know all rangers are 7.5 unless it was swapped...i could be wrong... the fx4s however did come with a 28 spline... but for your 97 im 80% its a 7.5 open diffrential
it'd wider and you'd have to have perches mounted closer together... And as far as i know all rangers are 7.5 unless it was swapped...i could be wrong... the fx4s however did come with a 28 spline... but for your 97 im 80% its a 7.5 open diffrential
Nope. 4.0s always had 8.8" rears.
The FX4 axles that are rare are 31-spline, like an explorer axle. The 7.5 and Ranger 8.8 are 28 spline.
There is nothing to tell you or I if it is open, chances are just as likely it is a L/S.
You sir are wrong too
