1994Rangerxlt
i got a 8.8 shell and i have 3.27s in it and i have a 3.73 ring and l/s but i couldnt get the pinion it was cracked.. ive read the pinion on a 7.5 and a 8.8 are the same 1.626shaft diamter. but the spline counts are diffrent 8.8 is 30 and 7.5 is 28 .. can i use the 7.5 pinion in the 8.8 and use the diffrent cap with the splines in it for drive shaft. or should i go back 2 junk yard and just get a 8.8 l/s 3.73 ring and pinion out of the explore along with axles and do a 31 spline axle conversion.. or can i just buy pinions with out ring gears. i also know were a pinion is in a empty hosuing from a 3.73 8.8 but i dont know how 2 get pinion out with out air tools andy info helps thanks
