daveguy
does any one use these leafs in rangers to lift the. without the shackle flip.
thanks dave,
thanks dave,
Yup, gotta move the front spring hangar ahead. Use the front lower hole for the back lower hole if your using stock leafs, and use the upper front hole to the body mount rivet if your using lift leafs.
This is using the lower front hole, you can see the upper rivet to use with lifted leafs.... which is what I SHOULD have done...
