63 64 leaf swap
I see alot of talk on here about swaping the stock leafs out for these larger chevy leafs and swaping the shackel what are the dif. aval setups and how much lift and articulation do you gain from them
I'm not a genius on the matter but I know a little bit about the 64" leaf swap because I've considered it for my prerunner. What I know is that with the 64" leaf you have to move the solid hanger in front forward, you want the shackles moved back a little and flipped, you want the leaves re-curved to 12" and you want a big off road type shock mounted to the leaf pack and a bed cage if some sort. With this setup I don't know what kind of lift you're looking at but I know with the right shocks mounted at the right angles you can achieve about 21" of travel on your rear axle.
Sent from my Windows Phone 8 using Tapatalk
