6 inch lift.... With 33's
89rangerboy
Is this a good set up on a 89 ranger....
I have so many plans for this truck....
Do you have any suggestions on who i should go with for a lift kit??
Any answers will be good THANKS~!!!!!:woot:
for a "drop bracket" lift kit, skyjacker. the piviots are pretty strong and well built. and they come with better springs than most I have seen in the 6 inch kits.
stay away from drop "plate" kits...
for a wheel travel kit with cut and turned beams, autofab middle of the road kit is a good kit.
Yeah... Price isnt an object...
Cause if i get it i wanna get the best and not have to worry about it...
Im not going to go rock crawling just some trail rides and some mud. =]
Unless you'll be jumping the truck/blasting around at hi-speeds, a Skyjacker kit sounds like what you're after.
If you go 6", get the bigger drop pitman arm with it (#FA600), as the one normally supplied with the kit is a bit too short for that amount of lift.
