the 04 civic was rumored to be a ford/honda project and the focus arrived shortly thereafter, thats why all the aftermarket parts for the 1.7 ivtec engine (intake manifolds headers etc) will work on the same yr sohc focus. they even shared the same cat eye headlight design. hell the focus uses the same turn signal clicker as a honda 50cc scooter, which i found hilarious. the newer model fords wont work w/ the newer civic parts, but the cat eye body fuktus and cat eye body sohc civic shared very similar engine design, body design, suspension design, and even exhaust routing. it was for these engines that had the tight internals and required the 520, thats which engine it was developed for. a friend of mine put 530 in one of those fuktus and almost immediately burned the rod bearings up. very slow to rev etc when it warmed up, and when he went back to 520 the bottom end was clunking, not very heavily but enuff to let you know that you skrewd up. rangers and other vehicles didnt see much dif in oil from what ive read, but that particular engine was very touchy and very like the civic in every way. thats where i got that info from, and i still think they worked together on that engine.
