5speed has a leak
daylight
tucson az
howdy l have 90 bronco ll 2wd. the trany has a seal leak at drive shaft. but
the drive shaft as cv joints instead of u-joints ok. so l'm searching for new part but ford does not stock any more, which is a shaft that goes into transmisson that attaches to the cv joint? where can l get this part?
thanks gil
what makes you think you need a new driveline rather than just a trans. output seal?
For real. That seal's a $5 part that takes 15 minutes to replace once you remove the driveshaft.
2wd - has a dummy Txfr case that has to come out too, my bad. Unless the PO put a 2wd tranny in there (non-factory config) and eliminated the dummy.
