Nullifier
- Oct 4, 2007
- Age
- 51
- Automatic
HI all I have a '97 2wd with 4.0 and auto obviously. I replaced the first tranny at 123K due to heavy use. My second tranny now has about 120K and is having issues. It is worse when cold but always a bit of an issue. It will not go into gear (Drive or Reverse) for probably a minute or more in the A.M. Then when warmed up will slip out of gear periodically when I slow or stop.
I hate to replace the tranny if it is a computor problem but I am throwing no codes when it happens so as far as the computer is concerned nothing is wrong. Any ideas on what to try. I have checked the fluid level and there is enough. Filter was was changed maybe 20K ago.
Thanks for the advise and yes I did a search first!
