Deluxedave
Started out to replace the clutch. After the first install, the truck would barely move. It turns out that I had neglected to remove a spacer/bushing from the vicinity of the slave cylinder when I installed a new throw out bearing. Just finished removing and reinstalling and it is now worse than before. The clutch will not release at all. I did bleed the system, but I am at a loss as to what would be causing the clutch to disengage. Any help would be appreciated.
