desertrat
My 98 Supercab has over 200,000 on it so I changed the oil in the tranny and transfer case, just as a precaution. I found some aluminum in the oil. That worries me because it seems to me the only aluminum is the case and that would mean I have a bearing spinning in the case. Does anyoone know if there is anything in the tranny that is aluminum other than the case?
The tranny works and sounds fine, and normal. Any help from someone that has been inside one will be appreciated. -------desertrat
