5.5" camburg system with 31's??
12345ranger12345
hey guys i have 31's on my bone stock 08 ranger xl
i was gunna get the camburg 5.5" kit for my truck
and what i was really wondering is if the 5.5" lift will look retarted with the 31" tires? camburg reccomends 31" tires, but i dont know how it would look...
if anyone has pictures or anything that would be great
thanks
eric
thanks
i might just go with 3" spindles and my 31's
cuz i honestly do not have the money to regear or else i would
and the 5.5 is 1800 and 450 for labor if its done by camburg. i live down the street from theyre shop, but thats 2250 that i do not have haha
thanks
eric
camburg & tires
I have a Camburg 5" on my 92 ranger with 31s. Some of my friends say I need a bigger tire but unlike MOST suspension systems Camburgs was made for real performance. So that 31 will go all the way up into the wheel well on full compression. 32's and 33's will fit if you drive around on the street but when you jump it for the first time good by tire and fender.
Also make sure you look at the rear fender clearance, I had to cut the inner fender out and add longer fender supports to push the fender out. My first jump with 31's killed the two back tires by cutting them on ther rear fender.
Also be careful with rim back spacing my 92 uses a 15x8 with 4" back spacing
