5.0 swap
Bajabuggy97
Hey all I know this has probably been asked or close too. I got a great deal on a 5.0 with a c6 trans. I know the 5.0 will bolt up. As far as I can read with the right mounts out of an explorer and the harness and tech. But I can't find anything if a c6 trans will bolt right up or fit under the ranger. I was aware the explorer one would bolt right into. Just curious. Since I already have the trans. If I could make it work. Any and all help with this swap would be greatly appreciated.
I have a 4l80 in mine with a 3 in body lift and plenty of room.
You will have to adjust the trans mount or make a new one.
You have a free pile of c6 transmissions or something? Not a good trans unless you need re donkulous strength.
It needs to be a small block ç6 unless your cutting it for a scatter shield.
In that case t400 is better drag raxing
