Waric
- Jul 28, 2017
- Automatic
Hey guys, new to the forum and looking for some info on a 5.0 swap with a manual trans. I've done some research and talked to a guy that's done a swap back in the 90's, and here's what I've come up with as far as the engine/trans.
1985-1992 5.0 (preferably mustang for H.O.)
Fuel injection with an ecu that will work with auto or manual trans without flashing or anything.
M5OD-R2 and t-case from a 97-03 4.2l v6 f150
This will need frame modifications and possibly a small body lift because of the trans/t-case width
Borg Warner T5 from a 1982-1993 (possibly not all the years, I haven’t researched variations in the years much) Chevy s10 4.3l v6 with a NP231 t-case
This fits between the frame rails and under the body without modifications, to the body/frame, and puts the front driveshaft on the correct side of the truck. The bellhousing needs changed (they are removable on the T5) and the input shaft needs changed from Chevy spline to Ford (I believe I read Ford is 10 spline). I found a couple different sources with pics and video showing the input shaft swap and it is simple, as long as you don’t knock anything out of alignment during the swap.
Engine mounts can be bought in a kit with the headers and oil filter relocation kit.
Trans mount will work with the M5OD-R2, It may need moved forward on the frame or holes in it be drilled out into slots.
T5 will probably need a “custom” mount, haven’t seen any info on this.
Clutch will need to be for a T5 to fit in the bellhousing.
Custom driveshafts will need to be made.
Both the T5 and M5 will put the shifter in the original hole in the floor.
Questions
I haven’t seen it mentioned anywhere, but would a newer 5.0/ECU (up to 96) from a mustang with a manual trans work as well?
Will the ranger hydraulic system work with either of these?
What year extended cab ranger would this work best with?
Is there another option for a 4x4 manual ranger?
What did I overlook?
Questions
