5.0 swap, trans?
N8sBroncoMI
Marquette, MI
86
after reading this
http://www.therangerstation.com/Magazine/summer2008/2_9-to_5_0-Swap.htm
I have a few questions, i have a 5.0 out of a 90 FSB with a40d and the wireing harness and computer, i was woundering if it would work with the trans in my 86 4x4 ranger or would i have to swap the trans and t case also, im new too all of these ranger parts so be kind -thanks
If your ranger has a c5 automatic it can be used with a c4 bellhousing and valve body; but imho, you'd be better off with the OD trans and transfercase from the '90.
yeah I had a 92 ranger 4x4 stx I did the 5.0 h.o swap and I used a AOD tranny from a mustang that used the TV cable that hooked to the throttle for tranny and I bought the adapter shaft and housing from James Duff to keep my 4x4 :icon_thumby:
well ill probably just run the 302,a4od,BW1356 setup out of the parts bronco then. thanks for the advice.
The E4OD is a large transmission compared to the AOD, and is quite a bit longer. The 1356 is also a very wide tcase, and will hit the framerail. You will need to clearance your framerail to fit it...an easier option is to either locate a Dana 20 out of an earlier Ford truck, like an EB, or get the advance adapters output shaft kit and run your stock tcase
SVT
