5.0 swap into 94 Ranger with a/c?
dlevi2121
Brownsville
Will this work with the a/c heater box? The truck is a 94 2 wheel drive so I dont want to do the body lift I have done 3 other rangers with the 5.0 swap but they were all first gen with no a/c or power brakes also this ranger has power brakes I guess i am getting kinda old I want the power and brakes and a/c lol let me know thanks all!!!!!:icon_cheers:
you can make it work.
in this situation i usually have the the oil pan modded a bit and sit the engine as low as possiblen biased toward the drivers side and tilted slightly up when using normal car efi intakes and or a 351...
basically take the engineside of the ac box off and make a new one out of hvac tin/aluminum flashing material. the later box could be fabbed in as well, or you can build a custom setup from a suburban/van rear type setup.
its only limited by the time your willing to put into it.
its hvac....just a matter of ducting air through the evap right:icon_thumby:
