4X4 push button switch removal.
RangerJ
North Georgia
I have 1994 Ranger 4x4 the push button hi low switch is bad I have a replacement,what is the easiest/safest way to remove the bad switch from the dash panel? Thanks
Never tried changing one but if you have a replacement you should be able to tell if is a snap in or screwed in from the back(meaning dash needs to be removed)
