DGamelin
- Jan 29, 2010
- none
- Automatic
I am a shop onwer and we have a 2006 ranger in here with a problem that we can't get to the bottom of, so I was wondering if anybody has delt with this? This truck is a meater reader truck for the power compy, no frils. 4l v6, auto, no lock out hubs of any kind axel is live all the time. 2wd, 4wd, 4wd low tranfer case. the truck has 73k miles on it.
Problem- When the truck is going 45mph or better in a straight line in 4wd about every 200 yards there is a loud and scary bang.
First we replaced the rear ujoint and the one in front to start, they needed them anyways.
The fluid in the tranfer case has no metel fillings in it. And be bcause you can't check the front diff we pulled the diff. Thinking the front spider gears might be bad. NO the inside looked good. We did replace a right axle seal and left wheel bearing.
Going by the fluid from the transfer case it was hard to believe anything was bad. But after checking and rechecking the actuator motor for the 4x4 it seams good. We pulled the case and it looks good inside.
It feels like the chain is jumping or it is jumping in and out of 4wd. But there is no sign of that inside the case. It does have matching tires.
Any Ideas?
Any Ideas?
