Ike4x4
- Oct 25, 2008
- Automatic
So i went through all of the diagnosis steps that were kindly laid out for everyone...found here. Everything worked out ok (including the self-diagnosis with the blinking red light on the module) until i got to step 5-C where it tells you to back probe the orange wire and check for 12 volts when the truck was turned on and the 4x4 button was pushed. I found that i didn't get any voltage. On to setp 6 according to the instructions.
In step 6 came the real problem, i didn't get 12 volts or 0 volts like it said. i did get 5 volts though. well actually 4.99 from the dark blue and 5.03 from the blue/white one. Everything else after step 6 checks out fine. I also cleaned out the shift motor and replaced it correctly....i've done it a few times before...usually that's what the problem is.
so there it is. Just don't know where to go after that. What else can i do or does anyone know what this means?
