4x4 not engaging 2000 ranger
kikylep
okay now i have a 2000 ford ranger and i live in some pretty harsh winters here in north Dakota but my four wheel drive has not been engaging and my little vacuum pump has gone out in it so i just manual engaging then but today i was driving and switch over in the schools parking lot and got into a spot that was about 4 or 5 inches deep covered in snow but then i drove out and leaving the parking lot i noticed that the back end was slipping out so i checked if my four wheel drive was in and the light was on so then i switched it off and then switched it back then tried it again and the same thing so then i turned it off and then went to a hill and got it so the back wheels would spin then i switched it over hoping i would hear a thud (i no its not the best thing in the world to do but its a easy way to check) so there was no thud so i assume that maybe it was the shifter motor so i went under the pickup and listened and i had my dad switch it over and i could here the shifter motor switched over so then yeah gave up and turned to you guys
oh i forgot to also add that i can no longer put it into 4wd low so yeah idk
its possible that your t case is shot but very unlikely. maybe the switch on the dash went bad. that happens alot too. do you know which transfer case you have?
okay found out that it was a stupid ****en hub so now the question is how do i found out the size i need for manual hubs that are reliable
