Z.Byers
- Apr 27, 2013
- Automatic
Hello, I have a '94 4.0L automatic Supercab Ranger with manual hubs. I recently put it in 4Hi to get out of my yard, since then the 4x4 light has remained on. It has push button 4x4. When I push the button in Park, it does not do anything, and the relay behind the driver set does not make any noise. If I put it in Neutral, the relay behind the driver clicks, but it doesn't shift. The hubs appear to be fine. I jacked up each tire and locked/unlocked the hubs and they turned and stopped turning the front drive shaft. Is the shift motor stuck, perhaps? Any ideas as to what the issue may be?
Thanks in advance for your help!
