Drunkcaballo
- Mar 31, 2009
- Automatic
I know this subject has been beaten to death but I still havent found an answer anywhere yet for the 4x4 solution...
Obviously the T5 to the BW1350 is not an option anymore...so what options do I have. I see that Advance Adapters makes adapters for a Jeep NV3550 to adapt to the bell housing and then another adapter to get back to the BW1350. Im sure by the time all that is done the drive shafts would have to be modified since the lengths are likely different after all the adapting....
So instead of going through all of that...If I were to put a manual in behind the 302, change and relocate the transfer case, build new drive shafts...what would be the best option to put behind the 302 (best equals most economical, easy to find, and if any luck, have the stick not come through the floor boards next to the seat). M50D R1 mated to a ????
The truck will be used as a city driver and some light duty off road fun (Im easy on my vehicles...I dont like to beat them to death).
Thanks in advance!
Thanks in advance!
