4x4 electronic shift inop
rangerstx92
i have a 92 ranger stx 4.0 with a 5 speed. 4x4 was working great a week ago(b4 it snowed enough to really need it) went to work it was kindof icy so i used it worked fine left it in 4x4 came out after work roads were clear try to take it out of 4x4 and its stuck in 4x4. so i unlocked the hubs and drove home. get home comes out of 4x4 and stopped working. i just replaced the t-case motor about 9 months ago so im pretty sure its not the problem. i habe no power/ground at any of the pigtails on the module. the only place i have power is two of the poles on the switch. the module does nothing when i try to self test. its almost like its got a pigtail unplugged somewhere. if i can figure out whats wrong with it it would be great but im about at the point of changing it to a manual shift t-case. any info twards the electrical problems or swaping in a manual shift t-case would be greatly appreciated
Go to the junkyard and get a module, if your self test light is not working then it should be the module!
If you have trouble finding one , I have a spare that you can have!:icon_thumby:
