6.2
- Aug 19, 2011
- Automatic
When I'm in 4x4 the system will clunk, and bang every few seconds and disengage periodically, but works fine other times. No I'm not on hardpack surface. this happens in mud, loose snow, sand, etc.
I replaced the U joint on the front shaft, it was a little worn but not bad. Issue still exists. the front CV shafts are fine. I removed the driveshaft and put it in 4x4 to see if it was the transfer case, problem didnt happen but that could also be because there was no load on it.
I have determined it's either the CV joint on the front driveshaft (transfer case end) or something else that I can't think of.
Any ideas? Am I on the right track with my thinking?
