- Aug 7, 2007
ya the b2 front beams will bolt up...and you could always slap in the dummy t-case from the b2 so you dont have to get rid of your tranny..or if you want a ranger 2wheel drive frontend you need to change the engine cross member...i say if you want to do it...do it..just give me your front end..i can put it to some very good use
The simplest way by far to convert a 4WD transfer case to a dummy is to disconnect the front driveshaft...
