4WD STOPPED WORKING 4W HI LIGHTS UP 4W LOW USED TO WHEN IT WORKED
PINTHEUS
10+ Year Member
Toledo
3.0L
NOT SURE 3" TO 4" maybe
245 75 R16
I HAVE ZERO TRANSFER CASE EXPERIENCE,, BELT OR CHAIN DRIVEN ? I DON'T KNOW,,can someone give me an idea what to look for.,obviously I only have RWD at the moment,,could it be a chain or belt or fluid or a combination & if anyone has a good TRANSFER CASE 1999 RANGER 3.0 GIVE ME A SHOUT,I LIVE IN TOLEDO OHIO THANK YOU
If you have push button 4wd you rarely use and it just quit working it is likely the shift motor.
It is an easy part to replace, you can service them if you want as well.
Yeah, that, it's a definite thing on these, they need to be cycled every few months to make sure they work. On a '99 I think there's pulse vacuum hubs up front too
i would wiggle the wire connections first
