steveoelo
Mighty Canuck
- Mar 26, 2016
I know I already posted a thread similar to this but I checked under the conversion section in tech article and couldn't find what I wanted. I'm curious on if I can swap the transmission, transfer case, front axles etc out of a 4wd into a 2wd? Both are a 2.9 but one is a reg cab long box and mine is a extended cab. I know the drive shafts will be different but can it be done? What all would I need to change for it to be done? The donor drive runs and drives so swapping should be fairly easy
