4R70W shift cable bracket
fastpakr
Forum Staff Member
TRS Event Staff
Roanoke, VA
Edit - found one, so I'm good!
I'm looking for the shift cable bracket for a 4R70W. Any 5.0 Explorer should have it.
I'll look this weekend to see if I have one. If I finish up my V8 swap I'll be using a B&M Quick Silver and wont need it.
That would be great, thanks!
Bump! Still trying to chase this bracket down.
On another note - I'd love to find the vehicle side fuel pump connector from a '99 (or equivalent year) that's -not- from a flex fuel 3.0. Discovered yesterday that Ford prevents FFV owners from swapping to the higher pressure pump by using a different connector. The connector is on the crossmember directly aft of the fuel tank. I've temporarily reused my FFV connector on a 4.0 pump by repinning the connector, but it's a short term solution.
To clarify - what I'm looking for is the black version of the connector on the right that's grey in the below picture. It will have the tab clocked to match the black connector on the left below.
