Need to replace the pan gasket on my 4R55E due to leaks, figured I should do a full trans fluid flush but some say there is a drain and others say there is not on the tq converter for my truck. What's the correct answer?
There is no drain plug on ANY Ranger torque converter.
Here is the easiest/best way to do a complete flush and fill. I have done this numerous times.
http://www.amsoil.com/faqs/ATF_and_Filter_Change_Procedures.pdf
So basically you use the transmission to pump itself clean.
Did you read the PDF link I posted above? I would assume you haven't since you don't know how it works. Please read the link posted above to answer your question.How do you get the trans to pump itself clean? Run it with the pan off and let it fall into a pan?? Somehow that doesn't sound like the right thing to do.
Thanks
George
that link don't work
You answered your question on this one.Unless it's got contaminated or burned oil, there's really no reason to do a complete flush is there?
