351ranger
I picked up a 2000 ranger 2wd 2.5L and I'm having some trans issues. I've been doing some research and found a few people are having similar problems but not exactly.
For the most part it works ok but there is a whining sound that I hear as I slow down that sounds like a power steering sound but I know it's the transmission. Also sometimes 1st to 2nd shift is a little bit hard. Another issue is when I put it in reverse it takes a few seconds before it engages.
I've read these are known for blowing out the gaskets between the valve body, would this cause hard shifting between 1st and second? Also sometimes it shifts weird as I'm slowing down to a stop light.
So I guess my question is, should I change the valve body gasket? With it whining the way it is, it makes me wonder if it's on its way out? Mileage is at 120k.
Any input on this would be great, maybe if someone had similar stuff happen and what the result was would be great. Thanks
