- Sep 4, 2017
- Age
- 47
- Lyman
- State - Country
- ME - USA
- Other
- 1987 Ford bronco ii 2wd
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Total Drop
- 3'' front 4''back
- Tire Size
- 245 35 18
Like title states I have a 2.3 ecu running my 2.9 in my bronco ii. I purchased this bronco last September. It was under 100k miles.interior looked pretty clean.but i really didn't know how much of a mess it was really in until I got and home and started messing with it. As I started continuing the battle trying to fix all the water leaks this thing has . Which been a chore to say the least. I noticed 1 of the leaks was getting pretty close to the ecu in the broken kick panel.so I decided to remove it since i wasn't planning on driving it for a while as I worked on it. As I pulled it out I saw some writing on it.it said 1987 Ford ranger 2wd 2.3l.. now my question is if this truly is a 4cyl ecu is only 4 injectors being controlled on my 2.9l which has 6 injectors in it? It seems to run ok but starts up a tad rough at times. And it doesn't seem to idle up from cold starts and stalls. Im just wondering if it's because of the ecu that's in it causing this. Let me know.
