Shran
Junk Collector
Solid Axle Swap
Truck of Month
I guess it is that time of year again where I need to use my F250 and of course there is something wrong with it.
This time it is just running weird. It will sit and idle nice and smooth, and seems to be fine at any RPM when the truck is stopped. However if I am on the highway it just falls on its face at about 40mph (in 3rd gear, 3000rpm or so, right before shifting into 4th) and again at around 65-70 in 4th gear. If I floor it in 3rd or 4th at any speed it will sputter and surge really hard and backfire through the exhaust occasionally.
I have replaced the plugs, wires, cap and rotor within the last 500 miles but that was probably 5 or 6 years ago. I drive it to a campground once a year and once in a while to pick up lumber at Menards but that's about it.
I am going to replace the fuel filter since I haven't ever done that but any other suggestions? It seems fuel related, accelerator pump perhaps? It is virtually a factory stock engine except for a Carter AFB carb and somebody removed the smog and EGR equipment.
