- Jul 17, 2011
- Wilmington, NC
- 4.0 V6
- My credo
- it is what it is
ok ive got a 78/79 hp44 dsd (and 9" soon to come) im wanting to put in my 91 ranger. ive got a few questions... 1) as far as the yoke on the 44/9" are the u joints the same size as the stock u joints on my ranger (d35ttb) and will the stock shafts work?
2) as far as building the axles...im not really planning on doing any extreme wheeling as this will be a DD as well. i do want to build the axles somewhat (shafts gears brakes lockers)---> as far as shafts go im probably only going to be running 35-36" tires, i want to run 33 spline 44 shafts and 33/35 spline 9" shafts but not sure who to go with...YUKON, MOSER, ALLOY USA, ETC? as for gears i was thinking 456 YUKON or SUPERIOR (have a 4.0l) does anybody recommend one over the other? brakes i definitely want to go 4 disk all around...i know a lot of people run wilwood but im not sure if i want to fork over that amount for a light truck with half ton stock braking power? could i just run some fairly decent caps pads and rotors and may)? as for lockers i know i want a DETROIT in the rear, dont want to weld the front, was thinking a tru-trac or some other lunchbox locker in the front should suffice?
3) as for the front having cast wedges...will the radius arm mounts work with the ranger?
