- Jan 24, 2008
- Automatic
yea this is the cam im lookin at. said its the perfect cam for a truck. also looking at the edelbrock performer dual plane intake with a 650 edelbrock also. the headers im planning on runnin cut outs right behind the headers with te electric motor valve but on the regular exhuast have a 18 inch glass pack with around 3 to 4 feet of 3 inch pipe behind it and dumpin underneath the bed. open the cutouts should sound like thunder huh?and also thinkin of putting flame thrower kits on the cut outs. oil pump already in it runs at idle at 50 pounds then when gouge on it hits up to 75 i think or 65 not sure. so all i shound need is just a nice set of pistons to go with this setup huh? hows it sounding for a ranger truck?
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Cam and Lifter Kits
Part Type: Camshaft and Lifter Kits
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,400-5,600
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 270
Advertised Duration: 262 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.513 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Valve Lift with Factory Rocker Arm Ratio: 0.513 int./0.520 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Valve Springs Included: Yes
Outside Diameter of Outer Spring (in): 1.460 in.
Retainers Included: Yes
Locks Included: Yes
Valve Stem Seals Included: Yes
Timing Chain and Gears Included: Yes
Timing Chain Style: Double non-roller
Assembly Lubricant Included: Yes
Pushrods Included: No
Rocker Arms Included: No
Gaskets Included: No
Quantity:
Brand: COMP Cams
Locks Included: Yes
Quantity:
