- Aug 7, 2007
- Michigan
- My credo
- If you're not making mistakes, you're not learning.
http://www.youtube.com/watch?v=-FDkPENUzZQ
I actually wasn't waiting for my dad, I didn't have the knob screwed on the kill switch/power cutoff button and was trying to pull it out.
http://www.youtube.com/watch?v=RRsTIgWYefM
http://www.youtube.com/watch?v=U1NGsfTzIg8 < best one IMOHO
Still have carb issues, currently exhaust is dumping straight out of the headers, and there's bunch more to finish up including the front differential and driveshaft. BUT IT MOVED!!!
1980 302 - 6 .060 over ; 2 .090 over (not done by me, came that way)
Ford T-18
Ford Dana 20 (unlike Jeeps these two DO NOT mate together from the factory, thanks Jeep friends...)
6" skyjacker suspension lift
Jeep Dana 35 rear end Aussie locked - it was cheap, will be a welded 8.8 very soon
D35 front swap
33 x 12.50 ProComp MT's
4.56 gears
essentially a complete new wiring harness except for the headlights/tail lights, etc. Bascially the wire harness on the drivers side remained... mostly intact.
Bed mounted gas tank
Bed mounted radiator
NO Body lift
The only 2 moving mechanical parts that were still from the original Ranger that connect to eachother are the speedometer and speedometer cable, and the steering shaft and the steering gear box. Literally everything else is from some other vehicle make/model.
Spring break is the week after this week for us, hopefully I can tie up most of the loose ends.
Ford T-18
D35 front swap
4.56 gears
NO Body lift
