4" trailmaster lift attached to axel
Baby Raptor
Cedar Rapids, Iowa
I found a used 4" trail master suspension lift that is for'84-'97 rangers. I have a 93 nd the lift is still attached to the'86 axel it was used on....is the gear ratio the same if it is a stock axel? And would I be able to just put that axle in my truck?
86 would be a Dana 28. You have a Dana 35. Please do your research.
Trading the d28 for your d35 would be a considerable downgrade....
As to the gears, there were multiple used. You'd have to look at the VIN/axle code to figure out what gears are in your axles.
If the lift components are attached to an axle that's not in a vehicle it can't be tht hard to just take it all off the axle and put it into your truck.
